switch 1 module 5 asic-1 temperature crossed threshold
Dear all,
I have an issue on a switch  Cisco 6880 installed few days ago...
From the logs the following message appear:
Is this a recognized bug or I need to request an RMA of the switch module ?
In attachment some show output I already did.
Can anyone help me?
9 Replies 9
Reza Sharifi
 switch 1 module 5 asic-1 temperature: 84C
It maybe caused by high temperature in the room.  Can you lower the temperature in the room (make it cooler) and watch the logs again?
thank you for your reply, the temperature is ok..  I already did this tests.
Daniele.
Yes but the overruns are an issue i would look into that , your either maxing out the ports and dropping traffic or hitting the bug below
Mark Malone
I ran your show tech through teyh analyzer it did not pick up any hardware issues but may have a different bug alright as below , you may want to upgrade
Significant interface overrun errors
GigabitEthernet101/1/0/3 (22.6%)
GigabitEthernet101/1/0/5 (19.4%)
GigabitEthernet101/1/0/46 (67052.2%)
GigabitEthernet102/1/0/16 (32.2%)
GigabitEthernet102/1/0/21 (3758.5%)
GigabitEthernet102/2/0/4 (4465.7%)
GigabitEthernet102/2/0/5 (155.0%)
GigabitEthernet102/2/0/6 (21.7%)
GigabitEthernet102/1/0/8 (413327.2%)
GigabitEthernet102/2/0/1 (38.2%)
GigabitEthernet102/2/0/2 (427499.0%)
GigabitEthernet102/2/0/3 (1983.0%)
GigabitEthernet101/2/0/46 (2569.1%)
GigabitEthernet102/2/0/16 (42.8%)
GigabitEthernet101/2/0/31 (147935.7%)
GigabitEthernet101/2/0/22 (33417.5%)
GigabitEthernet101/2/0/27 (1039.1%)
GigabitEthernet101/2/0/24 (329.2%)
GigabitEthernet101/2/0/28 (197.9%)
GigabitEthernet101/2/0/29 (8768143.3%)
GigabitEthernet101/1/0/25 (25.5%)
GigabitEthernet101/1/0/21 (54.1%)
GigabitEthernet102/2/0/15 (80060.1%)
GigabitEthernet101/1/0/39 (19578.1%)
GigabitEthernet102/1/0/11 (642.6%)
GigabitEthernet101/1/0/48 (3701.6%)
GigabitEthernet102/1/0/15 (19844.9%)
GigabitEthernet102/1/0/14 (334.1%)
GigabitEthernet102/1/0/28 (263.6%)
0 input errors, 0 CRC, 0 frame, 2415919104 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 1711276032 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 2634022912 overrun, 0 ignored
19 input errors, 18 CRC, 1 frame, 536870912 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 3825205248 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 3070230528 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 3858759680 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 436207616 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 1828716544 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 385875968 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 4227858432 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 2365587456 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 1258291200 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 1627389952 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 587202560 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 1879048192 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 4043309056 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 3187671040 overrun, 0 ignored
113 input errors, 53 CRC, 60 frame, 1811939328 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 1224736768 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 3372220416 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 3992977408 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 2013265920 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 2583691264 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 2080374784 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 2902458368 overrun, 0 ignored
0 input errors, 0 CRC, 0 frame, 4093640704 overrun, 0 ignored
Significant interface input giant errors
TenGigabitEthernet1/5/14 (66.7%)
TenGigabitEthernet1/5/15 (28.4%)
TenGigabitEthernet1/5/16 (22.8%)
Port-channel20 (13.6%)
TenGigabitEthernet2/5/13 (7.1%)
TenGigabitEthernet2/5/15 (5.1%)
TenGigabitEthernet2/5/14 (30.4%)
TenGigabitEthernet1/5/13 (75.8%)
Port-channel10 (24.1%)
0 runts, 803767310 giants, 0 throttles
0 runts, 1870188846 giants, 0 throttles
0 runts, 1370989158 giants, 0 throttles
0 runts, 109898006 giants, 0 throttles
0 runts, 8534223 giants, 0 throttles
0 runts, 8075314 giants, 0 throttles
0 runts, 100544611 giants, 0 throttles
0 runts, 1482189968 giants, 0 throttles
0 runts, 3791542106 giants, 0 throttles
This C6880-X-LE device running 15.2(1)SY4 is hitting:
may have hit the following software defect:
CSCus47027 - Input Overruns Counter on 6800-IA Incorrect
<br />
Symptom:
On 6800-IA switches attached to 6880-X-LE switches in VSS, the Input Overruns error counter in "show interface" output will randomly increment or increment at a rate that is not possible.
Conditions:
The output of "show interface " will list a high number of input overruns on 6800-IA interfaces. This counter may increment by a large amount periodically.
Checking the same output on the 6800-IA itself (via the "attach fex" command) will show no input overruns.
Workaround:
None at this time. This appears to be a cosmetic issue.
<br />(Please note that only 5 instances are reported but there could be more)
10704017390 packets input, 15408479451599 bytes, 0 no buffer
1668695499 packets input, 2155149849858 bytes, 0 no buffer
101773672 packets input, 30304818854 bytes, 0 no buffer
2489715482 packets input, 1805741441572 bytes, 0 no buffer
0 packets input, 0 bytes, 0 no buffer
I don't understand better. you said that this is not an hardware issue so Have i to open a case to cisco or can I take other solutions ?
Thank you.
Daniele.
when i ran your show tech through the analyzer it didnt pick up any hardwrae issues , it reported back fine , but it has picked up a software issue so you could look into upgrading , its only a cosmetic bug though so it should not be service effecting but its making the ports look like there over utilized
<br />
Symptom:
Conditions:
Workaround:
ok Can you advice me what ios version upgrade to ?
I find this version suggested by cisco :
Release 15.3.1-SY2 ED
https://software.cisco.com/download/release.html?mdfid=286305096&flowid=79696&softwareid=280805680&release=15.3.1-SY2&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Can this be ok ?
Thank you so much
Daniele
hmm your running this below on the switch its not a sup 6 and when I check your already on the latest recommended image
boot-start-marker
boot system bootdisk:/c6880x-ipservicesk9-mz.SPA.152-1.SY4.bin
boot-end-marker
Latest recommened image for your switch
https://software.cisco.com/download/release.html?mdfid=284855056&flowid=47922&softwareid=280805680&release=15.2.1-SY4&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Is the alert still appearing in logs for the temperature on module 5  can you post the command and check there is nothing blocking ASIC 5 ...........show environment
yes, the message error persist.. In attachment you can find the show commands...
