switch 2960 issue
wajid dabir
Level 3
Level 3
hi,
i have one WAN router (i.e. juniper router). on internal port i have configured two public ip( 56.10.45.225/27 & 56.10.246.97/28)
i have connect this router to my switch 2960-s by  fiber uplink and created SVI on switch VLAN 1.all ports of switch belog to vlan 1 only.
and i have connected the servers to same switch.
Now the problem is i can reach to gateway i.e. 45.255 & 246.97 from the servers and not able to reach from the switch.i am not able to ping the gateway address from the switch.
I configured default gateway as primary IP of router i.e. 45.225.
What can be an issue, how do i troubleshoot.
Wajid
Rolf Fischer
Level 11
Level 11
Hi Wajid,
when the server can reach the the gateways and you're using VLAN 1 only, we can assume that Layer-2 works.
1) Check the IP configuration of the SVI:
show ip interface vlan1
Vlan1 is up, line protocol is up
  Internet address is 192.168.1.4/24
2) Check that the default-gateway is within the same subnet as VLAN 1
show run | i default-gateway
ip default-gateway 192.168.1.1
3) Check ARP resolution for the default-gateway:
show ip arp 192.168.1.1
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.1.1         55   0000.0c08.bc01  ARPA   Vlan1
4) Check CAM table entry for the MAC-address:
show mac address-table address 0000.0c08.bc01
Vlan    Mac Address       Type        Ports
   1    0000.0c08.bc01    DYNAMIC     Gi0/1
Rolf
