Switch 2960X initial failed
Trung Minh
Level 3
Level 3
Hi all,
i have a switch 2960X with stand alone.
When i turn on it is showing strange characters such as:
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒G▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒g▒33ofs▒{ll▒▒▒q▒▒▒�▒sΏ▒▒▒▒▒▒▒·▒▒▒▒▒▒▒▒▒▒·▒▒p▒▒▒▒▒▒▒▒▒▒o▒▒▒▒▒▒Þ▒▒▒▒▒▒▒▒▒▒▒7▒f▒▒▒▒
After that it is stopped, then i have to press enter or space that cursor can continue but still cannot boot.
Any help is appreciated,
2 Accepted Solutions
Seb Rupik
Hi there,
Have you tried changing the baud rate of your terminal session? 9600 and 115200 bps are the most common ones to see in use.
cheers,
Seb.
It seems that the switch has two boot image entries. Check the "show boot" command output and delete the entry which is matching to failed ISO version 152.2.E7.
no boot system flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Seb Rupik
Hi there,
cheers,
Seb.
Hi Seb,
Seem .bin file crash so i upload to new file and now running well.
But at loading how it is showing error load the old bin, how to delete this message?
Loading "flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin"...flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin: no such file or directory
Error loading "flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960x-universalk9-mz.152-4.E8.bin"...Verifying image flash:/c2960x-universalk9-mz.152-4.E8.bin....................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
Any advise is appreciated,
Deepak Kumar,
Hi there,
Your config is specifying the old image, which is why the first boot attempt fails. The bootloader then finds your new image in the flash root and loads that one.
As @Deepak Kumar correctly points out, you need to remove the old boot statement. You should also add a new boot statement for the new image:
boot system flash:/c2960x-universalk9-mz.152-4.E8.bin
cheers,
Seb.
