switch 3560 uplink to 5548 in vpc
FedeSaraullo
Hello everyone! I have a doubt about if it is possible to connect a 3560 switch to two 5548 nexus in vpc mode. I suppose that i have to configure a portchannel on the catalyst, i haven´t found this topology with this switch, only with the 3850 or 3650.
Thanks in advance!
Mark Malone
yes its the same , the 3560 just needs to be standard po and the po on the nexus switches needs to be in vpc mode ,example below , same for all catalyst access switches once they support etherchannel
On both nexus switches
interface port-channel15
description VPC 15 xxxxx
switchport mode trunk
no lacp suspend-individual
switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39,48,50,64-65,72,74,76,78,80,105
logging event port link-status
logging event port trunk-status
vpc 15
interface Ethernet1/22
description xxxxxx
channel-group 15 mode active
Then on 3560 just normal PO
description xxxxx
Mark Malone
vpc 15
description xxxxxx
description xxxxx
Thanks Mark! You have been very kind.
Bye!
