Switch 3750 Multicast issue
co-operaciones
Community Member
                   Hi, the 3750 version is:
12.2(44)SE5
The OSPF/EIGRP is not working through the 3750.
The sesions is no configured in the 3750 this is just a distribution switch to my customer.
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(50)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 26-Mar-10 06:38 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02900000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
DIST-SW-3750-1-HOWA-HOWA uptime is 1 week, 6 days, 6 hours, 57 minutes
System restarted at 02:11:14 EST Sat Aug 3 2013
System image file is "flash:c3750-ipbasek9-mz.122-50.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-48TS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1225W09X
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:22:0C:41:E1:80
Motherboard assembly number     : 73-10218-08
Power supply part number        : 341-0107-01
Motherboard serial number       : FOC1224616N
Power supply serial number      : AZS1215036R
Model revision number           : F0
Motherboard revision number     : C0
Model number                    : WS-C3750G-48TS-S
System serial number            : FOC1225W09X
Top Assembly Part Number        : 800-26857-02
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COM7X10ARA
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750G-48TS     12.2(50)SE4           C3750-IPBASEK9-M
     2 52    WS-C3750V2-48TS    12.2(50)SE4           C3750-IPBASEK9-M
Switch 02
Switch Uptime                   : 1 week, 6 days, 6 hours, 57 minutes
Base ethernet MAC Address       : 28:93:FE:D8:B3:00
Motherboard assembly number     : 73-11762-05
Power supply part number        : 341-0328-01
Motherboard serial number       : FDO14130PM5
Power supply serial number      : LIT140505EJ
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C3750V2-48TS-S
System serial number            : FDO1413Y0NF
Top assembly part number        : 800-31053-02
Top assembly revision number    : A0
Version ID                      : V02
CLEI Code Number                : COMGS00ARA
Configuration register is 0xF
co-operaciones
Community Member
La cosulta fue creada con la cuenta incorrrecta.
Algun administrador que cierre el tema.
Mil disculpas.
