03-08-2021 04:37 AM - edited 03-08-2021 04:39 AM
I want to factory reset my 3750 because we lost admin password. [ 3750 ios 12.2(25) SED1]
I succed to arrive at the point :
The system has been interrupted prior to initializing the flash file system to finish loading the operating system software:
flash_init
load_helper
boot
switch: flash_init (i type flash_init, but when i hit "return" nothing happens, no prompt nothing, waited one hour nothing happens !
Connex 9600/none/8 working etc etc !
Best Regards
03-08-2021 09:14 PM
flash_init load_helper rename flash:config.text flash:config.text.bak boot
03-08-2021 10:14 PM
Hi, sorry but when i type flash_init , just after it hangs i can't do cariage return to validate... Si thé process can't start...
03-08-2021 10:28 PM
Sounds like the flash could be failing.
03-09-2021 12:10 AM
- Try : fsck flash:
M.
