Switch 3750G-12S-S Configuration
wafaawassif
I have one switch 3750G12S
I joined the company new,
I found that they want to replace it with Alcatel stack switches.
I didnt configure this Cisco switch before.
I need some help on how to configure it.
I have 4 other new cisco switches in the topology which is not created yet.
the 4 switches are all 2960.
Need some help please.
17 Replies 17
Wafaa you are very welcome however it is much better for everyone especially you to post your questions here this way you not only have a single resource but multiple resources to help you out and suggest best practices , does that makes sense?
Feel free to ask any questions you have we all would be happy to help.
Thanks Mohamed for Replying, Thanks Joseph too,
I had configued the switch as L3
and made two vlans 100 and 200, first for data, second for voice, but I didnt
give an IP address for Vlan1... shall I leave it for management?
Then I connected 3750G-12S with 2960S with SFP through fiber...
The first Alcatel design was 3 switches stacked together and one of them connected to
packeteer to firewall to router.
Is it possible to do the same after configuring the core switch as L3.
or I will face problems.
One more question, why I cant connect to Cisco network Assistant,
is there any special configuration that I have to do.
Note: I have configured the first 4 ports for the 3750G-12S-S as trunk
so I can connect other switches as you and Joseph has suggested.
Note" I have Made Gi 1/0/12 as the port which will connect to the packeteer, but I dont know how i will configure it"
this is part of the configuration on the Alcatel switches that I have to replace them with the cisco ones
BBWS4-> write terminal
! Chassis :
system name BBWS
! Configuration:
! VLAN :
vlan 1 enable name "VLAN1"
vlan 1 router ip 192.168.133.4 255.255.255.0  e2
vlan 2 enable name "VLAN2"
vlan 2 router ip 192.168.134.4 255.255.255.0  e2
vlan 2 port default 1/48
vlan 2 port default 3/1
! VLAN SL:
! IP :
ip service all
! IPMS :
! AAA :
aaa authentication default "local"
aaa authentication console "local"
aaa authentication snmp "local"
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
session prompt default "BBWS4->"
! SNMP :
snmp security no security
snmp community map "private" user "user" on
snmp station 192.168.136.21 1062 "user" v2 enable
! IP route manager :
ip static-route 0.0.0.0 mask 0.0.0.0 gateway 192.168.133.10 metric 1
ip static-route 192.9.215.0 mask 255.255.255.0 gateway 192.168.133.5 metric 1
ip static-route 192.168.117.0 mask 255.255.255.0 gateway 192.168.133.5 metric 1
! RIP :
! OSPF :
! BGP :
! IP multicast :
! Health monitor :
! Interface :
! Link Aggregate :
static linkagg 1 size 4 admin state enable
static agg 1/49 agg num 1
static agg 2/49 agg num 1
static agg 3/49 agg num 1
! VLAN AGG:
! 802.1Q :
vlan 2 802.1q 1 "TAG AGGREGATE 1 VLAN 2"
! Spanning tree :
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper address 192.168.133.20
! System service :
! VRRP :
VRRP DELAY 45
! Web :
! AMAP :
! GMAP :
! Lan  Power :
! NTP :
!RDP :
BBWS4->
BBWS4-> show spantree
Vlan STP Status Protocol Priority
    1      ON     802.1D   32768
    2      ON     802.1D   32768
BBWS4-> show vlan
                                         mble
vlan  admin  oper  stree  auth  ip  ipx  tag   name
    1    on    on     on   off   on  NA   off   VLAN1
    2    on    on     on   off   on  NA   off   VLAN2
Can you share your switch config as a text file ?
