Switch 4500 VLan
wfares
Community Member
i face a problem with the VLAN , i try to create more than one VLAN and there is a Microsoft DHCP server to provide the IP address , i create the vlan and there is a ping between the vlans on the core switch and i can get an ip address form the dhcp server which is 10.0.12.15 but it didn't work on other vlan and i use ip helper address with no use , but there is something strange happen when i use static ip on a pc on any vlan it can't ping any pc on the native vlan until it ping on it so i clear words i have a native vlan 10.0.12.X and VLAN 4 10.0.3.X i can't ping any pc form vlan 4 to vlan 1 until i do the same form vlan 1 to vlan 4 first then it work , so how can i solve the dhcp problem , with the attached is the configuration , please help
11 Replies 11
andrew.prince
Level 11
Level 11
If you want to communicate from a vlan to another vlan you MUST have a layer 3 interface for the VLAN.
From your config - taking vlan 189 for example. Even if you open this interface and put a port into the vlan - the PC will NOT be able to ping or do anything. As the frame is layer 2 with a vlan id of 189. Without a layer 3 interface IP will not work - you need a layer 3 interface to break out the layer 2 frame.
From you config - which vlan is not getting a DHCP IP address from your DHCP server?
all vlans didnt get an ip address fornt eh dhcp server except it works with the native vlan 10.0.12.2 but as i think the 4500 switch is a layer 3 device so it can route between the vlans
OK - have you defined the scopes in the DHCP server in the correct range?
The VLAN interface has to have an IP address.
An example would be:-
The DHCP server 192.168.1.1
int vlan 1
ip address 192.168.1.254 - native vlan
int vlan 33 - frames tagged with vlan id 33
ip address 192.168.33.254
ip helper-address 192.168.1.254
int vlan 66 - frames tagged with vlan id 66
ip address 192.168.66.254
int vlan 99 - frames tagged with vlan id 99
ip address 192.168.99.254
When a device on vlan 66 requests an IP address via DHCP, the vlan interface will receive it (as it's a broadcast)
and the forward it on, acting as a "proxy". the DHCP server will recevie a request for an IP address from 192.168.66.254
then reply with an IP address out of the scope of address 192.168.66.x - a simple breakdown and explaination.
HTH>
so if i do the the following will it work or not the dhcp server ip address is 10.0.12.15 if i use for the helper address dose it work or i have to use the ip address of the native vlan which is 10.0.12.2 as an helper address
Add the below to each VLAN layer 3 interface that you want machines in the VLAN to get an IP address from the DHCP server:-
int vlan xxx
ip helper-address 10.0.12.15
The DHCP server MUST have a scope of addresses that MATCHES the IP address of the VLAN Layer 3 interface IP.
HTH>
wfares
Community Member
so as i have understnad if i create a dhcp scop 10.0.3.x and creat a vlan 4 with ip addrees 10.0.3.1 will not work the vlan ID must match the scop like
vlan 3 10.0.3.x /24
vlan 4 10.0.4.x /24
NO - the VLAN IP addresses MUST match the scope in your example:-
vlan 3 - 10.0.3.x/24 = scope 10.0.3.x/24
vlan 4 - 10.0.4.x/24 = scope 10.0.4.x/24
if you wanted to allocate 10.0.3/4 in a scope then you would have:-
vlan3 - 10.0.3.x/23 = scope 10.0.3.1 <> 10.0.4.254/23
This is basic IP subnetting & VLSM.
HTH>
well after trying everything i get the following
1- When i use a client on the same VLAN as the DHCP server it work great without any problem
2 - when i use the same pc on another vlan and use a static IP address it work and ping between the two vlan great
3 - but when i use the same pc with dhcp on the other vlan it didn't work i try to debug the dhcp traffic and it give me as in the attached file so where will be the problem now , can u help
The switch is passing on the DHCP request - the server is responding with an IP address for the machine = all looks OK.
Post the config of the core switch - remove any sensitive information (passwords etc)
dose the ip route has any relation in this because i didn't use it i delete the ip route and the default gateway
Let me ask you:-
What does an IP route do?
What does a default route do?
Then you decide if you need them on a core switch that has layer 3 interfaces that connect directly to VLAN 1 that has the DHCP server connected, another VLAN that has a PC directly connected.
