Switch 4507R compatibility
umum00029
Dear all,
      The following is the original module on the switch 4507R.
        Its version is      boot system flash bootflash:cat4000-is-mz.121-13.EW.bin
CMDOWNLOAD#sh mod
Mod  Ports Card Type                              Model             Serial No.
1      2  1000BaseX (GBIC) Supervisor(standby)   WS-X4515          JAB071604SU
2      2  1000BaseX (GBIC) Supervisor(active)    WS-X4515          JAB07150552
3     24  10/100/1000BaseTX (RJ45)               WS-X4424-GB-RJ45  JAB070905HP
4     48  10/100BaseTX (RJ45)                    WS-X4148-RJ       JAE07081DLY
5     48  10/100BaseTX (RJ45)                    WS-X4148-RJ       JAE07081G8B
6     48  10/100BaseTX (RJ45)                    WS-X4148-RJ       JAE0727102L
7     48  10/100BaseTX (RJ45)                    WS-X4148-RJ       JAE0716065N
Due to upgrade the module on the switch 4507r, I replaced the new Gigabit module for original module 4 (100MB based)
However, I got the error message:
                  0:06:44: %C4K_CHASSIS-3-UNKNOWNLINECARD: Unknown module (Field Replaceable Unit minor type 340) in slot 4
and saw the module status as following
1      2  1000BaseX (GBIC) Supervisor(active)    WS-X4515          JAB071604SU
2      2  1000BaseX (GBIC) Supervisor(standby)   WS-X4515          JAB07150552
4      0  Unsupported module                     WS-X4548-GB-RJ45  JAE0918B1S9
I found many information showing that WS-X4548-GB-RJ45V is supported by 4507R......
Should I upgrade my IOS?
Thank you so much.
2 Accepted Solutions
Jon Marshall
Thank you so much.
Yes you need to upgrade your IOS. You need a minimum of 12.1(19)EW to run that module. From the release notes -
WS-X4548-GB-RJ45
48-port 10/100/1000BASE-T Gigabit Ethernet switching module
12.1(19)EW
12.1(19)EW1
Jon
Ganesh Hariharan
Dear all,
CMDOWNLOAD#sh mod
Yes you need to upgrade the ios to support for the module check out the below link for more information about the ios supported.
http://www.ciscosysteme.org/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Jon Marshall
Thank you so much.
WS-X4548-GB-RJ45
12.1(19)EW
12.1(19)EW1
Jon
Ganesh Hariharan
Dear all,
CMDOWNLOAD#sh mod
Hope to Help !!
Ganesh.H
