switch 48 ports with 10 Gbps port -copper
Is there a switch that handle its 24/48 ports at 10 Gbps with copper?. I have checked  3750 X but just handle 2 SFP with 10 Gbps.
The requirement is to use this switch as CORE and connect 12 switches (access) using  its uplinks at 10 Gbps  with copper ( in this case 3750 X can be used).
any recommendation?,  using copper at 10 Gbps the distance is still 100 m?
regards.
9 Replies 9
Leo Laohoo
Nexus 2232 with a Nexus 5K to control and configure the 2232.
Cisco Nexus 2000 Series Fabric Extenders
Reza Sharifi
Can it be a chssis based switch, if yes, there is 48 port 10Gig copper for the 6500 series
have a look:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_bulletin_c25-575203_ps4835_Products_Bulletin.html
Hi Reza,
Thanks a lot for you time and recommendations.  5 for you :-)
Its a good option, the problem is that is very expensive...$$$$
anyway I take into account.
regards
darren.g
Level 5
Level 5
regards.
Nexus 3064 with Twinax copper cable SFP's.
And no - you're not going to get 100 metres at 10 gig over copper off a Cisco device. Some manufacturers claim to suppoet 10GBaseT, but I'm yet to find one which will work at close to 100 metres. The longest support I can find for a Cisco device is 10 metres. Power requirements for running 10 gig over copper are quite large, so not a lot of switches will support it at this point in time.
Cheers.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
There's a new module for the 3750X, the C3KX-NM-10GT.
10GB-T Module
The new Cisco 10G Base-T module is hot-swapable and can operate at either 10GE or GE speed (with manual configuration).
Table 5 shows the cable types and supported lengths of the new Cisco 10G Base-T module.
Table 5. 10GB-T Cable Types and Supported Lengths
Cable Type
Supported Length
Category 7a
100 meters
Category 7
100 meters
Category 6
55 meters
Category 6a*
100 meters
* Category 6a requires 3db Insertion Loss margin at 250MHz.
Joe,
But this module only support 2 10Gig copper interfaces.  The OP is looking for 24/48
Disclaimer
Posting
Reza Sharifi wrote:
Joe,
Oops!  (Thanks Reza)
In that case, looks like a chassis would be needed, although if only 24 10 gig copper ports are really needed, then two "4900M 8 port 10GBase-T (RJ-45) half cards" with eight X2-10GB-T modules might be considered, see:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/product_bulletin_c25-575166.html and http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa.html.
Hi Joseph,
I really appreciate your time for giving me this option (4900M).
I'll check it.
regards
10GB-T Module
Cable Type
Supported Length
Category 7a
100 meters
Category 7
100 meters
Category 6
55 meters
Category 6a*
100 meters
Cool. I couldn't find that one for looking. I might bear that in mind for a future deployment possibility!
Thanks for pointing this out.
Cheers
