Switch 4948E compatibility ISE
Rss
Frequent Visitor
Frequent Visitor
Does anybody knows if the switch 4948E is compatible with ISE, CoA, redirection, dACL, etc?
Thanks for your help
Jason Kunst
This is not something listed directly with ISE compatibility
I did a google search for the 4948 and it does support dot1x and apparently COA as there is a listed of a bug fixed, so yes it should support these flows although not officially tested with ISE if the features are supported then TAC should support
redirect-url and redirect-acl are not cleared after a successful CoA, causing the final step of Central Web Authentication to fail.
Workaround: Return a dACL in the authorization profile with successful guest authentication.
CSCue62019
Jason Kunst
CSCue62019
Rss
Frequent Visitor
Frequent Visitor
Hi Jason
Thanks for your help.
I did some test and worked, but I didnt put in product environment  because the link said there is no compatibility, reason I prefer not use this switch.
Very thanks for your help.
Regard
If the switch supports the features of COA, dot1x, web redirection to external portal for CWA then you can run it in production. ISE team doesn't test every switch combination out there however but these are common features in most of the code. You should move forward if you want it
Rss
Frequent Visitor
Frequent Visitor
Hi Jason
ok, thanks for your help, and recomendation.
I´ll do that in a near feature
