Switch 6500 issue
I have a issue with a 6500 Switch. this show a log and i cant understand what is about, can you help me?.
Jul 6 06:07:18.234 gmt: SW2_DFC6: amd_flash_program_generic_x16 FAILED!! @ addr = 0xFFB529C8, op_status = 0xFBE4, value = 0x464
This event ocurred once o twice, but i need to know why?
7 Replies 7
Deepak Kumar
It is may be IOS bug or Flash memory issue.
Please share current IOS version. and Sho Version output
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
i attach this output. thanks.
I did not found any similar issue on cisco bug report page.
At this condition you need to following solutions:
1. Are you using Compact Card ? If yes then make backup and format card or replace.
2. Upgrade IOS version.
Let me know if you need any other information.
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
How can i see if i have a compact card? I don´t have fisical access to the device.
thanks
Leo Laohoo
Jul 6 06:07
Exactly how recent is this?  Time and date shows 06 July.
Post the complete output to the command "sh log" & "sh module".
6 of july was the last event. in fact there is not more message en el logging buffer. i attach the show module output.
If it's only happened once or twice, then I'm leaning towards an IOS bug.
