Switch 6500 VSS
battanc
I have a client with a couple of 6500 with supervisor 720-2B
Now he would activate a VSS between the 6500.
The supervisor don't support VSS and the question is: is there an upgrade for the 720-3B or he must change them ?
Best Regards
Claudio
glen.grant
  This page might answer some questions.  http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-virtual-switching-system-1440/prod_qas0900aecd806ed74b.pdf
Some questions, but not the mail question: is there an upgrade for the 720-3B or my client must change them ?
C.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You'll need to replace the sup.  The sup720 doesn't support VSS.
Also for VSS, only certain line cards are supported.
If you plan to replace your supervisor card (to support VSS), then you might as well get the Sup2T (same price).
Also you may want to look into getting your chassis replace.  Joseph might explain as long as he doesn't get into a "coughing fit".  winkwink
