Switch 9300 is reloading
Hi everyone.
I need a help... I have a Switch Cisco 9300 and he's reloading with no reason. When I do "sh version" I get the follow output
"Last reload reason: PowerOn " but the switch is connected in a nobreak and i have 2 powersupply":
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  PWR-C1-715WAC       LIT21494JFS  OK              Good     Good     715
1B  PWR-C1-1100WAC      DTN2211V3DS  OK              Good     Good     1100
Why this switch is reloading by himself?
12 Replies 12
Reza Sharifi
Is this a Nexus 9300 or Catalyst?
The issue probably is a software bug that is causing the switch to reboot. Upgrade to a different version and test again.
Is a Catalyst.
Switch Ports Model SW Version SW Image Mode
* 1 64 C9300-48P 16.8.1a CAT9K_IOSXE INSTALL
16.8.1a is ED. Try upgrading to 16.6.4a
cat9k_iosxe.16.06.04a.SPA.bin is a recommended version by Cisco.
viveks2
Thomaz,
Please share the following information from the switch.
1) show module
2) show logging onboard detail
1) show module
Switch Ports Model Serial No. MAC address Hw Ver. Sw Ver.
1 64 C9300-48P FCW2224G070 b090.7e17.bd00 V02 16.8.1a
2)i can`t do this command:
SWITCH1#show logging onboard ?
switch Switch
SWITCH1#
show logging onboard switch 1 detail
SWITCH1#show logging onboard switch 1 ?
clilog Show board Clilog data
counter Show board counter data
environment Show board environment data
message Show board message data
poe Show board POE data
status Show logging board Status
temperature Show board temperature data
uptime Show board uptime data
voltage Show board voltage data
show logging onboard switch 1 uptime
I would suggest opening a TAC case so that engineer can further investigate and look into hardware/software component. If you plan on opening a TAC case please attach following outputs.
1) show version
2) show module
3) show logging onboard switch 1 uptime
4) dir crashinfo:
5) Information about how frequently it reboot.
Good luck!
1. I agree with Reza. I would upgrade the firmware and see if this helps.
2. Next, post the complete output to the command "dir crashinfo-1:".
Yowmamen
Hi sir. Is this already resolved? May i ask what was the workaround to fix the issue
@Yowmamen
Create a new thread so we can have a look.
Mark Elsen
 - Activate syslogging for the device to a a syslog-server, look for any info(messages) around the time frame of the reboot.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
