Switch always going off every 2days
opeolaoya
Hello All,
I have a switch that goes of every two days on our network.. Please see sh logging details after a reboot was perform.
can anyone tell me what the issue might be
Note: this switch is connected to a Video Conference device
See show logging details i get on
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 30 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 30 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level notifications, 26 message lines logged
        Logging to 155.236.224.133  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              26 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 155.236.240.190  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 155.236.239.16  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 155.236.239.17  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 10.2.18.22  (udp port 514,  audit disabled,
              filtering disabled
Log Buffer (4096 bytes):
*Mar  1 00:00:36.574: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:00:37.908: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:00:40: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:40 UTC Mon Mar 1 1993 to 01:00:40 GMT+1 Mon Mar 1 1993, configured from console by console.
*Mar  1 00:00:44: %SW_VLAN-6-VTP_DOMAIN_NAME_CHG: VTP domain name changed to unite-phc.
*Mar  1 00:00:44: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan12, changed state to down
*Mar  1 00:00:45: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:13 by sasyamal
*Mar  1 00:00:45: %SNMP-5-COLDSTART: SNMP agent on host PHO-LAN-HEL-A-SW01 is undergoing a cold start
*Mar  1 00:00:45: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:45: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 155.236.224.133 Port 514 started - CLI initiated
*Mar  1 00:00:45: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 155.236.240.190 Port 514 started - CLI initiated
*Mar  1 00:00:45: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 155.236.239.16 Port 514 started - CLI initiated
*Mar  1 00:00:45: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 155.236.239.17 Port 514 started - CLI initiated
*Mar  1 00:00:45: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.2.18.22 Port 514 started - CLI initiated
*Mar  1 00:00:46: %LINK-3-UPDOWN: Interface FastEthernet0/18, changed state to up
*Mar  1 00:00:46: %LINK-3-UPDOWN: Interface FastEthernet0/19, changed state to up
*Mar  1 00:00:46: %LINK-3-UPDOWN: Interface FastEthernet0/20, changed state to up
*Mar  1 00:00:46: %LINK-3-UPDOWN: Interface FastEthernet0/22, changed state to up
*Mar  1 00:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/18, changed state to up
*Mar  1 00:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/19, changed state to up
*Mar  1 00:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/20, changed state to up
*Mar  1 00:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/22, changed state to up
*Mar  1 00:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to up
*Mar  1 00:00:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*Mar  1 00:00:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan12, changed state to up
*Mar  1 00:00:48: %LINK-3-UPDOWN: Interface FastEthernet0/23, changed state to up
*Mar  1 00:00:51: %LINK-3-UPDOWN: Interface FastEthernet0/10, changed state to up
*Mar  1 00:00:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/10, changed state to up
Oct 15 08:21:29: %SYS-5-CONFIG_I: Configured from console by opeoluwa on vty0 (10.155.169.156)
Oct 15 08:23:42: %SYS-5-CONFIG_I: Configured from console by opeoluwa on vty0 (10.155.169.156)
PHO-LAN-HEL-A-SW01#
5 Replies 5
Leo Laohoo
Post the "sh version" output.
Hello Leo see ''sh version'' output
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.10.15 11:34:50 =~=~=~=~=~=~=~=~=~=~=~=
sh ver
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
PHO-LAN-HEL-A-SW01 uptime is 2 hours, 24 minutes
System restarted at 09:09:59 GMT+1 Wed Oct 15 2014
System image file is "flash:c3560-ipservicesk9-mz[2].122-52.SE.bin"
 --More--         to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560-24PS (PowerPC405) processor (revision U0) with 131072K bytes of memory.
Processor board ID FDO1324X34F
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:26:51:6E:31:80
Motherboard assembly number     : 73-9673-13
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO132506JD
Power supply serial number      : DTN13214451
 --More--         Model revision number           : U0
Motherboard revision number     : A0
Model number                    : WS-C3560-24PS-S
System serial number            : FDO1324X34F
Top Assembly Part Number        : 800-25861-07
Top Assembly Revision Number    : A0
Version ID                      : V09
CLEI Code Number                : COMFJ00BRA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C3560-24PS      12.2(52)SE            C3560-IPSERVICESK9-M
Configuration register is 0xF
Has anyone checked the stability of the power source?  A good test would be to put a UPS between the power outlet and the switch and see if the UPS kicks in.
the switch is permanently on a UPS in fact the UPS has just been newly replaced.
Then use raw power.
