Switch & IOS compatible with Dynamic ARP Inspection (DAI)
Romain05
A client asked me to set up the DAI feature on their network.
I would like to know the compatible switches and / or the minimum version of IOS to set up the DAI feature.
Do you have a link with this information? I didn't find it.
Thanks !
Francesco Molino
You can go on Cisco IOS Feature navigator: http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
Select "Research Features", then a new page open up.
Then on Search For field, type DAI and click on Filter button. Select DAI and click on Add button and then Continue button.
Below the first table you'll get all IOS versions with switch models that are compatible with this feature.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
I had forgotten the existence of this feature, which is very interesting.
Thank you very much !
Romain
you're welcome
Francesco
