Switch and router configuration
muraripadhan
Level 3
Level 3
Dears
I have 5 department
1-HR
2-SALES
3-Customer service
4-IT
5-Planning Department
My IP class is B and my range is 172.141.0.0/16
My requirement is
I will assign IP for "HR" only 172.141.10.0/16 range
IP for "SALES" only 172.141.20.0/16 range
IP for "Customer Department" only 172.141.30.0/16 range
IP for "IT" only 172.141.40.0/16 range
IP for "Planning Department" only 172.141.50.0/16 range
And If someone give IP on HR with different range like 172.141.60.0/16 then it will not work
I want to assign specific range of IP for specific Department.
How i will configure
Please suggest me and give config file.
Thanks & Regards
Murari Mohan Padhan
Julio E. Moisa
You need to use VLSM in order to provide proper amount of hosts per subnet, or you could assign a /24 for each department, but you could waste IP addresses. May I know the amount of required hosts per department?
Attached you will find a VLSM file that could be useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Julio E. Moisa
Deepthi
Hi Murari,
1. The IP segment you selected is not a private IP segment. So, need to use one of these IPs for your internal corp. usage.
     10.0.0.0        -   10.255.255.255  (10/8 prefix)
     172.16.0.0      -   172.31.255.255  (172.16/12 prefix)
     192.168.0.0     -   192.168.255.255 (192.168/16 prefix)
https://tools.ietf.org/html/rfc1918
2. You cannot get  /16 subnet from a /16 network. So, you would need to go for more small subnets. I suggest you to use VLSM techniques for this.
http://www.aboutmyip.com/AboutMyXApp/SubnetCalculator.jsp
-Hope these information helps...
Have a good time..
But we are using this network in our LAN...since 15 years
Hi Murari,
I am not pretty much sure why your corp. are using those IP addresses, but as per the industry standards, those are not the recommendations.
Those are the public IPs used by AOL Inc. if am not wrong according to my search.
IP Address 172.141.0.0
Location  United States, Virginia, Dulles
Latitude & Longitude of City 38.997708, -77.433179 (38°59'52"N   77°25'59"W)
ISP AOL Inc.
So, maybe I am guessing that you are using those IPs internally without routing it to the open internet.
Even with you set up, you cannot get 172.141.10.1/16 segment from another 172.141.0.1/16 segment as i already informed.
The segment 172.141.0.1/16 involves all the IPs from 172.141.0.1 to 172.141.255.255 and so your requirement of subnetting would be wrong in this case.
So, you may go for smaller subnets such as 172.141.10.1/24, 172.141.20.1/24, 172.141.30.1/24 and so on which can be accommodated within your 172.141.0.1/16 subnet.
Results
Address: 172.141.0.0 10101100.10001101.00000000.00000000
Netmask: 255.255.0.0 11111111.11111111.00000000.00000000
Wildcard: 0.0.255.255 00000000.00000000.11111111.11111111
Network Address: 172.141.0.0 / 16 10101100.10001101.00000000.00000000
Broadcast Address: 172.141.255.255 10101100.10001101.11111111.11111111
First host: 172.141.0.1 10101100.10001101.00000000.00000001
Last host: 172.141.255.254 10101100.10001101.11111111.11111110
Total host count: 65534
Yes we are not routing in open internet it is using internally
