Switch C9300 48x not reloading after reset all command
Biju KIV
I tried to reboot to factory default by the reset all commands. Now its not reloding. Attached screenshot
7 Replies 7
Hi @Biju KIV
 Try to run the dommand "dir" from this switch prompt. dir flash: could show you the IOS inside the flash.  Then you can try to boot the IOS with the boot command
Leo Laohoo
While the switch is still in ROMMON, post the complete output to the command "set".
The switch is showing
Switch:
It's not moving fwd.
Even switch:dir flash: shows empty
hi @Leo Laohoo
Hi Atthached the set commnd
Post the complete output to the ROMMON command "dir flash:".
Biju KIV
hi,
managed to install the new firmware with the below comments
switch: emergency-install usbflash0:/<filename.bin>
request platform software package install switch all files flash: <new file> auto-copy
reload (reboot)
request platform software package clean (remove the old)
Biju
