Switch Catalyst 3550 Series Firmware
victorr43
Community Member
Hello community, I have an old switch Catalyst 3550 Series, I need the lastest firmware for this switch and I can't find it on the website because it's out of support, I don't know if anyone can help me, thanks.
M02@rt37
Hello @victorr43
Unfortunately, the Cisco Catalyst 3550 series switches are no longer supported, which means that you won't find the latest firmware updates available on Cisco's official website.
Best regards
Thanks, is there any way I can search for it in any other site? Regards.
@victorr43 hi, you can try googling the switch model. but that cannot guarantee you will get verified firmware and use it at your own risk.
Good luck
KB
Yes @victorr43  but like @Kasun Bandara said "that cannot guarantee you will get verified firmware and use it at your own risk."
Best regards
