Switch cisco 2960POE + Unifi AP AC reboot every minute
sebr
Hello everyone
for my association I just changed our switch the old switch was a Linksys SFE2000 24ports POE, I had no problem with my 2 terminals wifi Unifi Ap Ac.
I replaced this switch with a Cisco Catalyst 2960 POE 48 ports but now my wifi reboot every minute.
I tested at home with a live cable with another terminal is the same.
I read that there was several detection mode for the poe and that if the switch can not determine the power it sends 15.4w.
Can we change that?
What to do ? Is this switch not going for my terminals?
I have a small Netgear 8-port POE switch on the GS108PE and the kiosk works well too.
Thank you for your answers.
sebr
Hello, I corrected my problem. By the terminal I passed the POE port in manual and configured 7w. The switch did not arrive in automatic to define the necessary power. A cisco questions the equipment to find out what he needs.
Following reboot the switch should not be able to find the right configuration and configure the port in 15w.
Following the manual configuration of the port with 7w the antenna remains now lit without problem.
sebr
