Switch configuration Analysis
fan.yang
Community Member
Hi guys:
I am the guy who has the Trunk problem last week. Finally, it looks the trunk port is working. But I still have some problem about this switch. I take some screen of the port/Vlan setting and the log message.
Can someone let me know what is the problem?
Julio E. Moisa
I think the port 1/7 is an access switch, right? apparently you have BPDU Guard enable on it also
On port 19/20 there is a native vlan mismatch, are they trunks? by default the vlan 1 is the native vlan (is not the best practice) and it should be the same on both ends.
What do you have connected there?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
