Switch front panel MODE button, how to read
mwillenb41560
Where in Cisco documentation is how to read a small switch
Front panel MODE button display on the LEDs
Looking at a catalyst 2950
I’m checking on a switch I do NOT have login access, want to just read the MODE UTIL bar graph correctly
  Looking for a cause of slow response between a router our organization owns and a switch a customer owns
  Is the bar graph linear or logarithmic?
if the green LED's are showing a constant level or 14 out of 24  and jumps up to 16 out of 24
  What Utilization is that?
And the amber LED's are at 24 out of 24   , that is 100% utilization
   Is it a 100% spike reached some time since power up?
   Or   100% spike reached in the last hour?
David Hornstein
Level 7
Level 7
Hi Marty,
Hopefully the following can answer your question as it relates  to the particular model within the 2950 series family.
start looking at around page 1-13 of the attached install guide.
regards Dave
