Switch in stack not coming up
jasongr33nway
Level 2
Level 2
Hello all. I have an issue. IOS image was applied to the master switch and on reload the master switch will not come back up. I know the issue is the other two switches in the stack have an older IOS than the master. I disconnected the master from the stack and it still will not come back up. Is my only option to console on, and reboot off the older IOS?
8 Replies 8
brselzer
What model switch is it? What version are you moving from and going to? There is a chance that the switch is dropping to rommon. You might need to console in and check what is going on when it tries to boot.
-Bradley Selzer
CCIE# 60833
2960x in a stack with a couple 2960s. IOS is 15.0(2)EX4 and loaded is 15.5(3)M7
Sounds like you might be using the wrong version. 15.5(3)M7 is a router IOS. A 2960s or 2960x switch can not run that. You could run something like 15.2(2)E8 if you wanted a newer version. You can see all compatible versions on the download page:
2960S:
https://software.cisco.com/download/release.html?mdfid=282864093&flowid=46690&softwareid=280805680&release=15.0.2-SE11&relind=AVAILABLE&rellifecycle=MD&reltype=latest
2960X:
https://software.cisco.com/download/release.html?mdfid=284795753&flowid=43251&softwareid=280805680&release=15.2.2E7&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Hope that helps. Thanks!
-Bradley Selzer
CCIE# 60833
Sorry, you're right. It's 15.2(2)E7 not 15.5(3)M7
I see. Do you know what filename you used? There are 2960s images and 2960x images and they are different. I imagine at this point you will need console access to the switch to see what is going on. Feel free to post any errors you are getting and I will take a look.
-Bradley Selzer
CCIE# 60833
I figured out what is wrong. The hostname was 2960s and it is actually a 2960x. I put the S image on it.
Did you reboot the stack or did you manually power reload the stack?
I am asking because there is a microcode bug affecting EX train.  When an IOS upgrade occurs and the switch is running an EX, a manual reload is required because there is a bug with the microcode.  When the bug kicks in, the switch will boot into ROMmon.
A complete power down is required.
Got everything back up and working this morning. Thanks for your help!
