Switch Login Super Slow and Radius Not Working
PolarPanda
Hi there,
       Usually, after I entered login info, It took like 1 sec to login. But after my cowork enable ssh v2 to login switch remotely, my domain network admin account cannot be login anymore. According to debug info, it kept to timeout by radius. It was normal to login switch via telnet. The domain network admin user is authenticated by radius server.  When I tried to use local user account to login switch, it took me almost 20 second to login (it's 1  sec beofre). so the issues I have now are 1. radius server not response 2. it takes too long login the switch. Can someone explain the potential causes for both issues? Thank you.
7 Replies 7
Reza Sharifi
What happens if you disable SSH completely? Does it go back to normal login (1 sec)?
Sometimes, enabling different features triggers a bug and if you disable and than enable it again, it goes away. If it persist after enabling it again, it may be bug in the IOS you are running.
Thank you. I can try it later.
Oleg Volkov
Can You share:
sh run | inc aaa
sh run | sec line
Helping seriously ill children, all together. All information about this, is posted on my blog
sh run | i aaa
aaa new-model
aaa authentication login default group radius local
aaa authentication login console local
aaa authorization exec default group radius local
aaa session-id common
sh run | sec line
line con 0
password 7 xxxxxxxx
transport preferred none
stopbits 1
line aux 0
transport input all
stopbits 1
line vty 0 4
password 7 xxxxxxxx
transport input ssh
line vty 5 15
have you tried to reload the switch ?
Hello
Have you tried setting the Radius timeout to a low value
radius-server timeout xxx
Kind Regards
Paul
Richard Burts
There are things about this environment that we do not know and that prevents us from being able to fully explain the issues. Was authentication using Radius added as part of implementing SSHv2? Does the Radius server respond to the switch for anything?
I believe that we can explain the delay when you attempt to login using the local account. In the partial config that was posted we see this
This says that for any authentication try the Radius server first and if it does not respond then use local authentication. So when you attempt to login using the local account it first sends its request to the Radius server. Then it waits for a response. If the Radius server does not respond the switch waits for the timeout interval before it then uses authentication with the local user ID and password.
Rick
Rick
