Switch looping solution needed
Bristel1282
Community Member
Hi, is there any way I could link these 3 switches and make the ports green without causing a loop. (L2 only)
5 Replies 5
Mark Elsen
  - @Bristel1282     Switches are supposed to transfer packets between connected nodes.
                              Why do you see the need to have a 'forced loop' ?
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
M02@rt37
hello @Bristel1282
Why do you want to create a loop ?
Depend of your final goal... you could customize STP regarding vlans and have a different L2 topology for each vlan ... depends of what you want !
Best regards
Possibly using multiple VLANs, as already noted by M02@rt37, they might do the trick.  As he described, different VLANs can have different L2 loop free topologies because of Cisco's PVST.
If you were to disable spanning tree on the orange link it should go green but you would in fact cause a loop.
-David
tinil
Nope. If you touch the STP it'll result in a broadcast storm
