Switch management - best practice
johnny_5
Level 3
Level 3
Network infrastructure consists of multiple stores connected with MPLS, everything back hauled to our data center for internet and resources. Every store has a router and a switch on premise, except for one which i will get to in a moment. Every router and switch has a Loopback assigned for us to connect.  At one store we have the router and 2 switches, think a main backbone  (L3 - 3850)and a downstream (L3-3750). Today the last PC got moved off of VLAN 1 on the downstream switch and immediately we lost remote connection. The switch is up and operational but I have no connectivity. Both switches are running EIGRP. Looking at the configs it appears that the downstream switch had it default gateway and an ip route statement using the IP address on VLAN 1.
Before my time the loopbacks were setup to use a single IP and get advertised in EIGRP.  Is there a best practice to setup a connection between 2 L3 switches? We were using the IP address of VLAN 1 to connect to this downstream switch as the assigned loopback never worked.
The router to the backbone uses a point to point which is advertised also in the EIGRP table. Is it best practice to use loopbacks at a "management" access IP? Could i use a point to point to connect both switches?
Francesco Molino
How to connect 2 switches acting as L3 devices?
You can have them trunked together for all needed vlans and have 1 SVI on each within the same vlan to be able to access them both.
If you want to avoid L2, then it will be best practices to have a p2p link to interconnect them and be eigrp adjacencies
In your case, if I understand correctly, the 2 switches are hosting hosts and you don't need to run eigrp between them, then 1st solution will better. On the 2nd switch, you will have a svi within 1 of the trunked vlans as i said before. Also you want to keep the default gateway command and disable ip routing because not needed.
Loopbacks are preferable for management because you can have an global IP Plan and use it on your acls, monitoring tools.....
Also, when applying ios hardening config, you can apply a standard config on every devices for the control-plane to authorized ssh access, scp... only on loopback interfaces.
Using loopback on a 2nd switch though will require to keep ip routing to make sure you can access it.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
8 Replies 8
Francesco Molino
Francesco
It may be best to show you a snippet of the issue - remote connectivity.
Backbone1
router eigrp 50
network 172.18.1.116 0.0.0.3<<<point to point with Router
 network 172.18.5.34 0.0.0.0 <<<Loopback address
network 192.110.100.0
 eigrp stub connected summary
ip default-gateway 192.110.100.1
interface Vlan1
ip address 192.110.100.1 255.255.255.0
Downstream1
router eigrp 50
network 172.18.5.35 0.0.0.0<<<Loopback address - unable to connect
interface Vlan1
Also when the change was made we created a loopback address for the 198.110.100.x network on our CORE switch within out datacenter for some NATing we preform on our ASA. To circle back I can remotly connect to the store router and the backbone switch but not the downstream switch(using loopback or VLAN IP).
Why do you have the same ip on both switches for VLAN 1?
Is it a copy/paste error on the forum or really the config applied?
As you don't have access to your downstream switch, change the ip of your backbone switch.
Francesco
Yes that was a typo, my apologies!
Downstream1
interface Vlan1
ip address 198.110.22.6 255.255.255.0
I'm a bit confused, if I can access the backbone currently via the loopback 172.18.5.34 then why change it? For the infrastructure as a whole we are using the 172.18.5.0/24 range for the loopbacks for all cisco devices. If I had another IP available in that range 172.18.5.x would assigning it to VLAN1 on the backbone and by using the ip route statement on the downstream and then advertise in EIGFRP correct the issue?
Backbone1
router eigrp 50
172.18.5.34 is already assigned to loopback interface on the core. If you try to assign another IP in the 72.18.5.x/24 range to vlan1, you will get a duplicate address error. That is the reason, you need a different subnet for vlan1.
Ip of vlan 1 on your downstream switch is in a different subnet that the svi vlan 1 from backbone.
This means your eigrp neighborship isn't coming up.
Can you share the show ip eigrp neighbo please?
Francesco
I created a new VLAN/30 for the switches to communicate. When I removed the default gateway statement off of the downstream i lost remote connectivity again. I added the IP of the backbone as the default gateway and it worked. Thank you for your assistance.
You're welcome.
Francesco
