switch mode for Dual ISP Setup
owen2
Hi All,
Currently, we have a single switch that connects the ISP link to our HA FTD Firewall.
We are looking for an expansion in secondary ISP. refer to attach dual wan
We are not sure if the switch that is connected in between should work in a stack or just trunk mode?
Cheers.
Richard Burts
I am not clear why you need 2 switches. But the question you ask is about 2 switches and so that is what I will answer. It seems to me that a stack would make it more simple and so I would suggest that a stack is preferred to 2 switches with trunks etc. But you could certainly make it work with 2 switches with trunks etc.
Rick
Richard Burts
Rick
@Richard Burts  HI, we want redundancy for the switches. 1 switch for ISP 1 and another for ISP2.
Thank you for the clarification. 2 switches does address a physical single point of failure.
Rick
