Showing results forĀ
Search instead forĀ
Did you mean:Ā
Switch model details required
Debabrata Majhi
We need best model for distribution switch along with SFP module name for the following
Minimum 24 X 1 SFP Gigabit Ethernet with 4 x 10 Gigabit Ethernet port
We have to match our existing switch WS-X45-SUP6-E Catalyst 4500 E-Series Sup 6-E, 2x10GE(X2) port with SFP Cisco X2-10GB-SR.The new switch will connect
MM OM4 fiber to our existing switch WS-X45-SUP6-E Catalyst 4500 E-Series Sup 6-E, 2x10GE(X2) port .
Please share the best model.
Debabrata
9 Replies 9
Leo Laohoo
We need to add this below module right?
C3850-NM-4-10G 4 x Gigabit Ethernet/4 x 10 Gigabit Ethernet network modules
In the datsheet
Note:The C3850-NM-4-10G module is supported only on the 48-port Gigabit Ethernet models or on the 12-port or higher 10 Gigabit Ethernet models.
The C3850-NM-8x10G and C3850-NM-2x40G modules are supported on the 24-port and 48-port multigigabit switches and also on the 24-port 10G SFP+ switch model.
The C3850-NM-4-1G and C3850-NM-2-10G modules are not supported on the 12-port and 24-port SFP+ models.
Could you explain this .
We have to purchase WS-C3850-24S and
C3850-NM-4-10G 4 x Gigabit Ethernet/4 x 10 Gigabit Ethernet network modules to reach
Please suggest.
Debabrata
Debabrata,
In that case, WS-C3850-24XS will be compatible with the C3850-NM-4-10G.
Hi Leo
Can we use this 24 X 10 GE SFP+  as 24 X 1 GE port  SFP ?
Debarata
Yes.  WS-C3850-24XS can support SFP (Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix).
HI Leo
We have to match our existing switch WS-X45-SUP6-E Catalyst 4500 E-Series Sup 6-E, 2x10GE(X2) port with WS-C3850-24XS-S SFP+ port.
Please share the transceiver module name for this switch.We will use MM fiber OM4
  Port Type Transceiver Module Name
WS-X45-SUP6-E
X2
WS-C3850-24XS-S
SPF +
Debabrata
SFP-10G-SR for the 3850.
Hi Leo
Can we use
X2-10GB-SR for WS-X45-SUP6-E
Can we use X2-10GB-SR for WS-X45-SUP6-E
X2 optics are supported.
