Switch model recommendation
__21
Dear Expert,
Kindly i have a project that needs 14 switches with 8 PoE ports + 2 SFP up-links and all are interconnected to the main control room by SM Fiber cable. so my question is what's your recommendation about 14 switches and which core switch is compatible with it.
Many thanks in advance.
keglass
Level 7
Level 7
Muhammad,
Thank you for your interest in Cisco switches. I apologize for the delay in getting a recommendation for you. I have reached out to the Cisco switching team for a response, and you should hear from them soon.
Kelli Glass
Moderator for Cisco Customer Communities
Kelli Glass
Community Manager
Community Manager
From our switching team expert:
You could look into the Cisco Catalyst 3560CX family, specifically the one with 8 PoE ports. This is an access switch that is compatible with our Nexus or Catalyst 9300 switches (core).
There is one model on this family that has 8 ports with Power over Ethernet (PoE) and can be connected via SM fiber cable:
Name: Catalyst 3560X-8PC ( 8 GE POE ports, 2 GE SFP uplinks)
Part Number: WS-C3560CX-8PC-S
List Price: $1,695.00 USD
Links for reference.
3560 CX datasheet and comparison table
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-cx-series-switches/datasheet-c78-733229.html
http://www.cisco.com/c/en/us/products/switches/catalyst-3560-cx-series-switches/models-comparison.html
SFP Transceiver module matrix
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
I hope this helps. Please post back to this thread if you have any questions.
Kelli
Ronen Benjamin
You can also use the SMB series  such as  , price are few hundred $
SG300-10PP
SG300-10PP-K9
  8 10/100/1000 PoE+ ports with 62W power budget
  2 Combo mini-GBIC ports
SG300-10MP
SRW2008MP-K9
  8 10/100/1000 Maximum PoE ports with 124W power budget
  2 combo mini-GBIC ports
