Flexible Netflow not working on 4500X-16
maissiat
Dear All,
I would like to enable FNF on a 4500X-16 switches in VSS mode. I followed the guide from Cisco , but nothing is send to my collector (Prime 3.0)
Context :
Cisco 4500X-16 in VSS, IP Base license, IOS-XE 03.07.02.E  , remote site
Collector : Headquarter
WAN = VPN Tunnel 100Mb - Allow ANY
My config on the 4500X
flow record r1
match datalink dot1q priority
match ipv4 tos
match ipv4 ttl
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect interface input
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter e1
destination "IP Collector"
source Vlan96
transport udp 9991
flow monitor m1
exporter e1
cache timeout inactive 30
cache timeout active 60
cache entries 1000
record r1
Interface tengi1/1/4
ip flow monitor m1 input
It looks that no flows are collected
if I ran the sh flow monitor m1 statistics  cmd,  I see nothing , all fields are at zero.
. Any idea is warmly welcome, because I have a similar setup also on a remote site but  on 3750X and works fine.
Maissiat
18 Replies 18
Mark Malone
hey your missing match interface input/output and output features , can you try this it works for me no issues see flows , I use pi 3.0 and CA collector
flow record FLOW-RECORD
 description record to monitor network traffic
 match ipv4 tos
 match ipv4 protocol
 match interface output
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect transport tcp flags
flow exporter NetQos
 description export Netflow traffic to HQ
 destination 172.x.x.x
 source Loopbackxxx
 output-features
 transport udp 9995
 template data timeout 300
 option interface-table timeout 1000
 option exporter-stats timeout 1000
flow monitor xxxxxx
 description Used for ipv4 traffic analysis (Mapped To FLOW-RECORD)
 exporter NetQos
 statistics packet protocol
 record FLOW-RECORD
Dear Mark,
Thank you for your exemple , I tried it , but still have no flows.  I have a second 4500X on another remote site , I will try with this one. The IOS version is not the same  3.6, maybe there is an issue with the 3.7 version (didn't see any caveats on Netflow topic in the relase note).
Do you have also a 4500X , if yes which IOS version is installed ?
Maissiat
hey no i dont have 4500x but i do have flexible netflow running on multiple devices with this script above had it checked by TAC as well as i had an issue on certain routers and found out if output-features is not enabled it wont push the flow even though it did on certain switches without it
did you check the flow eporter what does it show ?
#sh flow exporter statistics
Flow Exporter NetQos:
  Packet send statistics (last cleared 1y6w ago):
    Successfully sent:         105357266             (137671530259 bytes)
  Client send statistics:
    Client: Flow Monitor xxxxxxx
      Records added:           2788777352
        - sent:                2788777318
      Bytes added:             131072535544
        - sent:                131072533946
    Client: Option options interface-table
      Records added:           6538947
        - sent:                6538947
      Bytes added:             653894700
        - sent:                653894700
    Client: Option options exporter-statistics
      Records added:           20252
        - sent:                20252
      Bytes added:             567056
        - sent:                567056
Hi ,
sh exporter statistics is empty, all at 0
Flow Exporter e1:
  Packet send statistics (last cleared 1w4d ago):
    Successfully sent:         0                     (0 bytes)
    Client: Flow Monitor m1
      Records added:           0
      Bytes added:             0
For me it like FNF is not active.. but why ...
there is known bugs on 4500x netflow take a look at this , could be the image
https://blogs.manageengine.com/network/netflowanalyzer/2011/01/25/missing-out-traffic-with-cisco-4500.html
I have this issue too. I ran 03.08.00.E but the exporter does not send any data.
The statistics are always 0. I tried several configs but whatever I configured it does not send any data.
Here is my current config:
flow record FNF-input
 description IPv4 NetFlow
 match datalink mac source address input
 match datalink mac destination address input
 match ipv4 tos
 match ipv4 protocol
 collect interface output
 collect counter bytes long
 collect counter packets long
flow record FNF-output
 match ipv4 tos
 match ipv4 protocol
flow exporter export-to-PRTG
 description export the flow to PRTG
 destination 172.16.130.30
 source Loopback0
 transport udp 2058
flow monitor NetFlow_input
 description IPv4 FNF ingress exports
 record FNF-input
flow monitor NetFlow_output
 description IPv4 FNF egress exports
 record FNF-output
I applied it to interface Te1/1/4 with:
ip flow monitor NetFlow_input Input
The statistics are always empty:
sh flow exporter statistics:
Flow Exporter export-to-PRTG:
  Packet send statistics (last cleared 01:14:47 ago):
    Client: Flow Monitor NetFlow_input
      Records added:           0
      Bytes added:             0
    Client: Flow Monitor NetFlow_output
      Records added:           0
      Bytes added:             0
What am I missing?
Kind regards,
Andreas
did you try UDP 2055 rather than 2058
3.6.6 is still the recommended ios might be worth trying that rule out the software , if its not that you can always move back up to 3.8 or try another MD release 3.8.0 is an ED
Hi Andreas,
I was able solve this by upgrading to 03.08.03.E.
BR,
Sebastian
Hi Sebastian,
hmm, 03.08.03E is a deferred release.
Kind regards,
Andreas
It wasn't when I did the upgrade five months ago :)
In this case, you should try 03.08.04E.
BR,
Sebastian
Just pick another Main Deployment release its most likely the software
Image's can get deferred instantly if something heavily critical is found Cisco can just remove them from download without warning set them as deferred
Hi Mark,
I was on 3.6 but no luck. I tested it on 03.08.00.E and 03.08.01.E both no luck.
I also changed the udp port... and send the data to my PC with wireshark looking for udp traffic - nothing. So, the counters from the statistics on the Switch are true.
If counters = 0 then no flow data is send... :(
Kind regards,
Andreas
Thanks but always same issue.. Wird.
I will change the switch :-)
No Still looking to resolve the issue.
Maissiat
Hi Maissiat,
What is the SUP on the switch? Here is an excerpt from a white paper--
"Flexible NetFlow is only supported on Supervisor Engine 7-E, Supervisor Engine 7L-E, and Catalyst 4500X."
Here's the link to the white paper, check if the prerequisites are fulfilled or if you're environment is hitting a limitation--
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1/XE_330SG/configuration/guide/config/fnf.pdf
Shaunak
