Switch module Install for 2951
Patrick McHenry
Level 4
Level 4
Does anyone have a doc for installing the a PoE switch module for a 2951? I find alot about the 2951 PoE Power supply but nothing for the switch module.
Thanks, Pat.
5 Replies 5
amohaida
What is the switching module you are going to install ?
Ahmad.
SM-ES2-24-P=
Thanks, Ahmad.
amohaida
Hi Patrick,
I don't think that there is a specific document for this enhanced etherswitch module , basically it is like any other netowrk module and you can install it following the steps in this document:
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/InstNetM.html#wp1046612
more useful information can be found in the following two links:
  • Connecting Cisco Enhanced EtherSwitch Service Modules to the Network
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/eesm_hw.html#wp1143505
  • General Information about Enhanced etherswitches modules on 299 and 3900 routers:
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78-553980_ps10537_Products_Data_Sheet.html
***** NOTE that OIR is NOT supported on 2900 Routers .  Please power down the router and remove the power  cord before inserting the module.  Otherwise, you'll risk  short-circuiting the "pins" at the back and cause components of the  module or the router to burn.
HTH,
Ahmad.
{Don't forget to rate helpful posts.}
Thanks for the docs.
Do you also have a doc for the configuring of a 4G module in the 2951.?
Thank you, Pat.
Hi Patrick,
Installing 4g card is the same as other interface cards:
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/inst_ic.html
Separate SIM installation instructions:
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/EHWIC-4G-LTEHW.html#wp1139200
As for configuring it, this is the guide:
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/EHWIC-4G-LTESW.html
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
