Switch on 3750 stack lost connectivity
Little Bunny
Level 2
Level 2
Hello
Users on switch 6 were unable to connect to the network for a while and we saw the switch change status to 'READY' for no apparent reason in the logs (it was working fine before.) Please see attached file for the switch logs. Any ideas on what might have caused this?
Amy
3750x, 6 switches in stack. Software version 12.2(58)SE2
Reza Sharifi
It appears that some one has disconnected and reconnected the stacking cables and that is was causing the logs.
does "sh switch details" show all the stacking cable are connected properly?
Thanks Reza. "sh switch details" looks good. I'll double check that they are all physically connected securely.
