3500xl switch will not accept interface range
philsvoice
I get a invalid input  range
   &nbSwPodx(config)# SwPodx(config)#int SwPodx(config)#interface range fastethernet 0/2 - 24
                                                          ^ % Invalid input detected at '^' marker. SwPodx(config)#sp;
7 Accepted Solutions
Jon Marshall
Phillip
The 3500XL is a very old switch and there is a strong possibility that the range feature was not supported on them.
If you do -
switch(config)# int ?
do you see the "range" option ? If not i suspect it is because the "range" feature was added after these switches had been phased out.
Edit - if that is the case then you will just have to do it port by port to allocate each port into it's correct vlan.
Jon
Sandeep Choudhary
Hi Phillip,
Interface range is supported only in 12.1(x). No plans to include interface range option in the XLs which cannot run 12.1.
To support the interface range command, your IOS must be at least release 12.1 or better.
Dont forget to arte helpful posts
Leo Laohoo
Interface "range", even if you are using the final IOS (WC17), is/will not be supprted.   This includes 2900XL and 3500XL switches.
The interface "range" option was supported only from the 2940/2950/2955, 2970 and 3550 switches.
Jon Marshall
Phillip
If the range command is not supported you need to do it one by one eg.
int fa0/1
switchport mode access
switchport access vlan 10
etc...
you could use a text editor and do it in there an copy and paste to the switch but it doesn't take that long.
Note from your configuration at the end the ports cannot be in both vlans at the same time ie they are either in one or the other.
Jon
Sandeep Choudhary
Hi phillip,
You must do manually on each interface.
Conf t
Int fa0/1
Jon Marshall
Phillip
See this thread for how to configure each port. Because the switch is quite old people have reported using the "switchport voice vlan x" command did not work.
So you can see the solution in the following thread -
https://supportforums.cisco.com/thread/2181858
note that you will have configure each port one by one because there is no "range" option on your switch.
Jon
Hi Phillip,
Normally it should work like this:
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 10
Switch(config-if)#switchport voice vlan 15
But I think its a verz old swicth,Correct?  OLDER switches must specifically configure the trunk in order to work.
Switch(config-if)#switchport trunk encapsulation dot1q
Switch(config-if)#switchport mode trunk
Switch(config-if)#spanning-tree portfast
20 Replies 20
Jon Marshall
Phillip
If you do -
Jon
Jon this is a voice lab and think I will be using Ip Phone and PC together.
vlan 10 is Data for PC
vlan 15 is Voice for IP Phone
vlan 11 is Management for gateway
Maybe this is why I have to assign 0/2 - 24 to vlan 10 and 15
correct ??
my vlan config for 3500xl switch is
vlan
name Data 10
vlan
name Management 11
vlan
name Voice 15
interface fa0/1
switchport trunk encapsualtion dot1q
___
I need to imput range below, what is the quickest way.  Thanks
int range 0/2 -24
switchport access vlan 15
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Per chance, did you clip and copy your config text from any word processors, e.g. Word?
Reason I ask, some of those will change a hyphen character to a dash character, and the latter isn't recognized in the range command.
Joseph
I don't know whether you saw/read a recent thread on oversubscription on 6500 linecard but the idea was raised of using rate limiting to control oversubscription.
Personally i have never done this and i don't think it is particularly practical but then i am no expert on QOS. If you get a chance could you have a look at it and see if there is anything i have missed or perhaps mislead the OP -
https://supportforums.cisco.com/thread/2262043?tstart=30
not a problem if you don't have the time.
Jon
Sandeep Choudhary
Hi Phillip,
Leo Laohoo
Jon Marshall
Phillip
int fa0/1
etc...
Jon
Is the configration asking me to assign int fa0/2 -24 to both vlan 10 and vlan 15
Phillip
Not sure i follow. A port is either a trunk where it can be in multiple vlans or it is an access port where it is one vlan. The only exception to this is if you are configuring a port with an IP phone connected where you have a data vlan and a voice vlan.
But your configuration doesn't look like there is a voice vlan so you can only assign each port into one vlan not both at the same time.
Do you need them to be in both for all ports ?
Jon
Sandeep Choudhary
Hi phillip,
Conf t
Int fa0/1
Jon Marshall
Hi Sandeep
How does that work ie. you are entering two "switchport access vlan x" lines where a port can only be in one vlan unless the additional vlan is a voice vlan.
Jon
HI John,
that was typo error, thaks for correction , I just copied from Philip post.
philsvoice
correct ??
vlan
name Data 10
vlan
name Management 11
vlan
name Voice 15
interface fa0/1
___
int range 0/2 -24
Hi Phillip,
