Switch performance measures
Hello
i need to know the best measures for a switch performance, what is switching capacity and forwarding rate? and how can i use these specifications to determine a high performance switch?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The two most common performance metrics are a switch's fabric bandwidth and its PPS rate.
A "high performance" switch generally supports wire-speed for all ports, concurrently.  Fabric bandwidth would be 2x all your port bandwidths.  PPS (for Ethernet) would be 1.488 Mpps per gig port.
For example, the original 4948 (48 x gig) is described as having a 96 Gbps fabric and 72 Mpps.
The original 3750G-48 (52 x gig) is described as having a 32 Gbps fabric and 38.7 Mpps.
The 4948 has the capacity to run all ports at wire-speed.  The 3750G-48 does not.  Yet, rarely do we really need switches with capacity to run every port at wire-speed, concurrently.  Further, just having wire-speed bandwidth and pps capacity does not guarantee optimal performance in all real-world situations.  Other features are just as or more important too, such as buffering capacity, non-blocking architecture, QoS, TCAM capacity, etc.
Leo Laohoo
Alot of people use the "forwarding rate" value.
What I'd like to know is what are you trying to do?
Where do you plan to use the switch?  DC?  Core?
I want to use it in the distribution layer to connect access layer switches, i have about 9 access layer switches to connect to this one.
How do you want to connect your access layer switches to your distro?  Fibre?  Copper?  Co-Ax?
What speed do you want your uplink?  100 Mbps?  1 Gbps?  10 Gbps?  40 Gbps?
What are connected to your access layer switch?
Joseph W. Doherty
Disclaimer
Posting
