3750 switch and routing
Anthony Walters
Currently have two routers inside our network.
One is the default GW 10.1.1.13
One is Jump Router for ATT 10.1.1.12
Both connected to HP Procurve L2 switch
The ATT Router is 10.1.1.2
Want to replace GW and Jump with one 3750 L3 switch.
Can I accomplish this with only one port g0/1 connected to HP Procurve?
Can I make the switchport 10.1.1.13 and then create a ip vlan999 10.1.1.12?
route all to 10.1.1.2
Am I crazy? Can this work?
Or do I just connect two ports, and hardcode them with an ip?
Thanks!
The question is not very clear. Could you please attach a rough topology diag.
We cannot have an Ip for a switchport. Switchport would be a layer to port.
Cheers,
AB
