switch port block unicast impact on voice traffic
vishal77
Hi All,
Is it entering command "switchport block unicast" on interface level/basis would impact (VOIP traffic) phones connected to that interface.
As im getting an few complaint that users are unable to hear voice while calling to other users.
Any help will be appreciated.
Hello VishalShah7719,
How Marce mentioned you can put storm control in switch ports.
This example shows how to enable unicast storm control on a port with an 87-percent rising suppression level and a 65-percent falling suppression level:
Switch# configure terminal
Switch(config)# interface gigabitethernet1/0/1
Switch(config-if)# storm-control unicast level 87 65
Other examples in link bellow:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swtrafc.html#71262
Also, you can increase mac-aging time, if necessary and use port security mac sticky to fix two or more MAC in the port. Careful the last command, this needs attention when you change/move host or phone another port.
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
6 Replies 6
Mark Elsen
 - Why do you want to use that particular command and or what are the needs for that command ?
    M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce,
Thanks for your reply.
 Basically  my aim is to enable  flood blocking on the switch of unknown unicast or multicast traffic is flooded to a switch port because a MAC address has timed out or has not been learned by the switch.
 - Simply blocking unicast traffic will be too heavy a measure because VoIP is unicast-traffic too. You may want to look into storm-control settings to protect against flooding. Google for instance on cisco ios storm control configuration examples , which will return a multitude of informational links concerning the subject.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Best regards,
Lucas Freitas
thanks buddy for your suggestion.
Also would it (switch port block unicast) impact data ports means laptop or computer connected ?
Reason I'm asking cause there's an audit happened at my company and they have suggested to enable such command on access ports.
When you use switchport block, you need MAC static or leaning by port security sticky, because if you don't have MAC in table, switch block traffic all unknown mac address.
switch# configure terminal
switch(config)# interface gi0/0/1
switch(config-if)# switchport block unicast
https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/nxos/commands/l2/switchport-block.html
Best regards,
Lucas Freitas
