Switch port config
Yasmeen
Hi team,
          while i run below command i am getting three interfaces why ?
EDISON-4-LAB-SWITCH#show running-config
interface GigabitEthernet1/0/48
shutdown
shutdown
no cdp enable
no cdp enable
18 Replies 18
Mark Malone
Thats not right , what happens when you do show ip int brief ? do you see 3 still ?
what switch and software is this on ?
EDISON-4-LAB-SWITCH#show ip int br
GigabitEthernet1/0/48 unassigned YES unset administratively down down
GigabitEthernet1/0/48 unassigned YES unset down down
Jaderson Pessoa
It is wrong... try show interfaces status and post here the result.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Gi1/0/48 notconnect 1 auto auto 10/100/1000BaseTX
That's not right.
What firmware is the switch running on?
That how do i check
what is the command for firmware
and
where i can see that firmware
Hello Yasmeen,
here we mean the IOS version
use show version this tells you the model and other information including the IOS running.
or
even
show version | include image
this tells the filename of the image running.
This might be a minor cosmetic software bug, it is not normal.
Hope to help
Giuseppe
EDISON-4-LAB-SWITCH#show version | include image
System image file is "flash:cat3k_caa-universalk9.SSA.03.06.03.E.505.152-2.5.5.E3.bin"
pls check it Giuseppe Larosa
Hello Yasmeen,
it would be nice to have also the switch model.
Try the following:
config t
default interface gi1/0/48
exit
and verify if this solves the multiple instances of gi1/0/48 in the configuration output.
Hope to help
Giuseppe
Hi Giuseppe Larosa,
After configure above command, again i am getting same command ,
switchport access vlan 47
switchport mode access
shutdown
no cdp enable
no cdp enable
Getting same error
Hello Yasmeen,
ok it didn't solved.
Ask for a maintenance window of half an hour and perfom a reload in that time window.
Before doing the reload collect all useful info
with
(enable logging to a file of printable output before on your telnet/SSH client software)
show tech-support
save the log file in a text file. For possible future use.
The reload may solve this issue if the triggering cause is the uptime that can be of several weeks or mounths.
Hope to help
Giuseppe
Ok Giuseppe Larosa, Let me try, will update here,
Thanks for support.
Model Number : WS-C3850-48P
