Switch port-security max address 1 does not limit at all.
gert00002
I tested the port security on c3560-advipservicesk9-mz.122-46.SE.bin as shown below. Despite setting a limit of one mac address, a burst of faked arp replies from 200.0.0.87 on port 23 killed the ARP table in an instant. Only the switch's own entry 200.0.0.11 survived (duplicate address detected, haha if he only knew!). Unused addresses are ignored "ignored gratuitous arp" but used go straight through. Setting the port security violation to restrict or protect is even more useless, because the attack can be repeated at any time.
Is this as expected?
What am I doing wrong?
SW1#show port int fa0/23
Port Security              : Enabled
Port Status                : Secure-up
Violation Mode             : Shutdown
Aging Time                 : 0 mins
Aging Type                 : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses      : 1
Total MAC Addresses        : 1
Configured MAC Addresses   : 0
Sticky MAC Addresses       : 0
Last Source Address:Vlan   : 00e0.4c53.4458:1
Security Violation Count   : 0
SW1#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  200.0.0.87              0   00e0.4c53.4458  ARPA   Vlan1
Internet  200.0.0.11              -   0014.a804.3240  ARPA   Vlan1
Internet  200.0.0.12              3   0012.d911.5940  ARPA   Vlan1
Internet  200.0.0.13              3   0008.e376.adc0  ARPA   Vlan1
Internet  200.0.0.14              2   f029.29ed.c140  ARPA   Vlan1
Internet  200.0.0.1               0   0011.2233.4455  ARPA   Vlan1
Internet  200.0.0.2               3   0015.63bd.7700  ARPA   Vlan1
Internet  200.0.0.3               3   0012.8017.9220  ARPA   Vlan1
Internet  200.0.0.4               3   0017.9496.7444  ARPA   Vlan1
Internet  200.0.0.5               3   081f.f36e.5632  ARPA   Vlan1
Internet  200.0.0.6               3   001f.6cec.5d74  ARPA   Vlan1
SW1#
01:46:34: IP ARP: rcvd rep src 200.0.0.1 0011.2233.4455, dst 200.0.0.30 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.2 0011.2233.4456, dst 200.0.0.31 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.3 0011.2233.4457, dst 200.0.0.32 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.4 0011.2233.4458, dst 200.0.0.33 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.5 0011.2233.4459, dst 200.0.0.34 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.6 0011.2233.445a, dst 200.0.0.35 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.7 0011.2233.445b, dst 200.0.0.36 Vlan1
01:46:34: IP ARP: ignored gratuitous arp src 200.0.0.7 0011.2233.445b, dst 200.0.0.36 0014.a804.3240, interface Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.8 0011.2233.445c, dst 200.0.0.37 Vlan1
01:46:34: IP ARP: ignored gratuitous arp src 200.0.0.8 0011.2233.445c, dst 200.0.0.37 0014.a804.3240, interface Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.9 0011.2233.445d, dst 200.0.0.38 Vlan1
01:46:34: IP ARP: ignored gratuitous arp src 200.0.0.9 0011.2233.445d, dst 200.0.0.38 0014.a804.3240, interface Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.10 0011.2233.445e, dst 200.0.0.39 Vlan1
01:46:34: IP ARP: ignored gratuitous arp src 200.0.0.10 0011.2233.445e, dst 200.0.0.39 0014.a804.3240, interface Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.11 0011.2233.445f, dst 200.0.0.40 Vlan1
Dec 20 15:45:20.424: %IP-4-DUPADDR: Duplicate address 200.0.0.11 on Vlan1, sourced by 0011.2233.445f
01:46:34: IP ARP: sent rep src 200.0.0.11 0014.a804.3240,
                 dst 200.0.0.11 0014.a804.3240 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.12 0011.2233.4460, dst 200.0.0.41 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.13 0011.2233.4461, dst 200.0.0.42 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.14 0011.2233.4462, dst 200.0.0.43 Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.15 0011.2233.4463, dst 200.0.0.44 Vlan1
01:46:34: IP ARP: ignored gratuitous arp src 200.0.0.15 0011.2233.4463, dst 200.0.0.44 0014.a804.3240, interface Vlan1
01:46:34: IP ARP: rcvd rep src 200.0.0.16 0011.2233.4464, dst 200.0.0.45 Vlan1
01:46:34: IP ARP: ignored gratuitous arp src 200.0.0.16 0011.2233.4464, dst 200.0.0.45 0014.a804.3240, interface Vlan1
Dec 20 15:45:20.449: %PM-4-ERR_DISABLE: psecure-violation error detected on Fa0/23, putting Fa0/23 in err-disable state
Dec 20 15:45:20.457: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0014.1232.1231 on port FastEthernet0/23.
Dec 20 15:45:21.456: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to down
Dec 20 15:45:22.462: %LINK-3-UPDOWN: Interface FastEthernet0/23, changed state to down
SW1#show arp
Internet  200.0.0.12              0   0011.2233.4460  ARPA   Vlan1
Internet  200.0.0.13              0   0011.2233.4461  ARPA   Vlan1
Internet  200.0.0.14              0   0011.2233.4462  ARPA   Vlan1
Internet  200.0.0.2               0   0011.2233.4456  ARPA   Vlan1
Internet  200.0.0.3               0   0011.2233.4457  ARPA   Vlan1
Internet  200.0.0.4               0   0011.2233.4458  ARPA   Vlan1
Internet  200.0.0.5               0   0011.2233.4459  ARPA   Vlan1
Internet  200.0.0.6               0   0011.2233.445a  ARPA   Vlan1
SW1#
SW1#
Rolf Fischer
Level 9
Level 9
could you tell us how you tested the port-security feature?
Port-security can only indirectly prevent from ARP-attacks because it inspects the source MAC-addresses of the ethernet-frames, whereas the ARP-table is built from the payload of ARP-packets.
Normally, the sender MAC-address in an ARP reply and the source in the ethernet frame should be the same, but that's not mandatory.
Have a look at this ARP-reply from a Microsoft "NLB" in "Unicast Mode":
As you can see, the sender MAC in the ARP reply is different from the source (this is, by the way, how they achieve their "Load Balancing": Downgrade a switch to a hub), so from a port-security's persepective, everything's alright.
If you want to prevent from ARP attacks on Catalyst switches efficiently, Dynamic ARP Inspection (DAI) would be the recommended solution.
Rolf
Hi Rolf,
I used the software Ostinato to generate the faked request, as seen in the debug, using the switch mac as the target.
The source mac address was anything and counted up, so for the switch it must be considered different systems "out there" sending. Else the switch would not shut down the port.
I just expected the switch to shutdown the port immediately upon receiving any packet with a second mac address. If I send the packets one per second, then the switch shut down the port after the first packed. But the switch got 100 Mbit ports. However, the requirement is to block any attempts to destroy the ARP table. Problably the switch have different processes for filling the ARP table and detecting "more than one mac-address used" violations. So if the attacker is fast enough he is winning. We may consider connecting all workstations with 9.600 baud, that will fix the problem ;-)))))
Fixing the Problem with DAI was considered, but that is not flexible and I don't think it will fix the issue either.
Gert
