switch port - stable amber in color
cyber.noc
hi, i have a switch 2924-XL and one of its port shows line protocol up but ite LED color is amber stable and the same port is access through a vlan but the connectivity cannot be established whereas if i used 2950 with same senerio it works, is there any solution for this.
jaz
wdrootz
Level 4
Level 4
If the port LED glowing in AMPER color it means Port is not forwarding. Port was disabled by management or an address violation or was blocked by Spanning Tree Protocol (STP).
