Switch port status connected no patch cable
hshabany
Hi All,
I have a Cisco 3560 switch. I have couple of ports in there that I cant use. When I connect a device to these ports I get network cable unplugged. The switch shows that these 2 ports are connected and packets are received through them. The interface status for these 2 ports is UP and UP. I cant seem to put my hand on what is wrong there.
10 Replies 10
Mark Elsen
 >these ports I get network cable unplugged
 - What do you mean by this sentence ? Also issue show logging on the switch , once the connection is mode ; look for errors if any (provide exact errors as provided by IOS)
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
When I connect a workstation to this port, it will show network cable unplugged. I have issued a show logging on the switch and no errors came up.
Julio E. Moisa
Probably the ports are damaged, try to make a reset of the ports, example:
conf t
default interface range fa0/15,fa0/20
And configure them again.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
I have already tried to reconfigured the ports again put the same thing happens. It is a fairly new switch, but I believe that these ports might be physically damaged.
Can I know which ports are?
ports 21 & 22 in a 24 ports switch.
Thank you, if you have made all the procedure to enable the ports and the same result, as you mentioned it could be a physical problem. If you have warranty you could open a case with the Cisco TAC to begin the RMA process.
Yeah, I have started a ticket with them. Thanks for the help
You are welcome.
Leo Laohoo
What is the IOS version this switch is running on. I remembered reading a bug with description like this. The workaround was to shut/no shut the port.
