Switch Port Troubleshooting.
ray_stone
Hi Experts:
There are two Switches connected with ESX Server and port ethernet 0/19 being used which is configured in Trunk port and now server team is reporting that the port does not seems to have been working fine.
I checked the switch port status and found the below stats:
3-admn# sh int ethernet 1/19
Ethernet1/19 is down (pauseRateLimitErrDisable)
  Hardware is 10000 Ethernet, address is 000d.ecf6.235a (bia 000d.ecf6.235a)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s, media type is 10g
  Input flow-control is on, output flow-control is off
  Auto-mdix is turned on
  Rate mode is dedicated
  Switchport monitor is off
  5 minute input rate 0 bytes/sec, 0 packets/sec
  5 minute output rate 0 bytes/sec, 0 packets/sec
  Rx
    238796366 input packets 238750261 unicast packets 45685 multicast packets
    420 broadcast packets 126013405 jumbo packets 0 storm suppression packets
    1039029980064 bytes
    0 No buffer 0 runt 0 Overrun
    0 crc 0 Ignored 0 Bad etype drop
    0 Bad proto drop
  Tx
    353714828 output packets 38671888 multicast packets
    75897612 broadcast packets 130489679 jumbo packets
    1083376474176 bytes
    1 output CRC 0 ecc
    0 underrun 0 if down drop    0 output error 0 collision 0 deferred
    0 late collision 0 lost carrier 0 no carrier
    0 babble
    45685 Rx pause 0 Tx pause 0 reset
4-admn# sh interface ethernet 1/19
  Hardware is 10000 Ethernet, address is 000d.ecf6.1c9a (bia 000d.ecf6.1c9a)
  Encapsulation ARPA
  Port mode is trunk
  Last clearing of "show interface" counters 86w6d
  Rx
    85932103994 input packets 85931903050 unicast packets 27872 multicast packets
    173072 broadcast packets 50722478635 jumbo packets 0 storm suppression packets
    287375253166073 bytes
    0 Bad proto drop
  Tx
    73040264335 output packets 27839138 multicast packets
    61844640 broadcast packets 32775514649 jumbo packets
    202201808046510 bytes
    1 output CRC 0 ecc
    0 babble
    27872 Rx pause 0 Tx pause 0 reset
Need your help to understand the problem as I am not best in Switch troubleshooting. Please help to understand the cause of the problem and provide the solution.
Thanks.
7 Replies 7
Leo Laohoo
Error disable?
what does it mean and why it caused... any specific reasons....
Tagir Temirgaliyev
I did connect  ESX Server to switch is configured as access port
Multiple V-LAN configured on ESX Server and to communicate with each other you need to configure switch interface as a Trunk Port so that it could support multiple v-lans traffic that you want to allow.
I am just wondering as to why the error disable encountered and what is a solution to fix it.
Thanks.
Ports are pauseRateLimitErrDisable - meaning Nexus is getting too much Pause frames from server:
So Nexus receives excessive Xoff pause frames from the server, then ports become error-disabled due to the high rate of pause frames received.
Usually the port will go into an err-disable state due o pause frames, only if the drain rate is less than 5mbps on a 10G
port. This means that the server is very slow (or misbehaving) and is sending a large
number of pause frames to the switch ports.
I am sending you the following link for your reference:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/n5K_ts_fcoe.html#wp1030594
So the problem is most likely with slow or misbehaving server which send Pause frame again and again even on slow traffic rate. Check that with server team and then unblock Nexus port (shutdown/no shutdown if needed).
Nik
+ grade if it helped
HTH,
Niko
+5 Nik.
Learn something new each day!
Thanks Leo.
HTH,
Niko
