How do I configure an ELAM on a 6500 running advipservices 12.2(33)SXJ
sgonsalv
Hi Guys,
I know that an ELAM can be setup on a 6500 running ipservices 12.2(33)SXJ, however I noticed that following commands are not available on a 6500 router running advipservices 12.2(33)SXJ:
show platform capture elam asic
etc
So I wanted to know if there is an alternate way to setup an ELAM for troubleshooting purposes?
Any info would be much appreciated.
thanks
Sheldon
nkarpysh
ELAM belongs to a set of hidden TS commands. Those can be enabled configuring "service internal" command in conf t mode. This command is also hidden so you need to copy paste that exactly to run.
Nik
HTH,
Niko
