SWITCH Port w/ Two VLANs?
I need to setup Voice and Data VLAN. (Setup - PoE phone connects to the switch, PC connects to the phone)
Say like, I'm connecting the phone to Fa0/1, and I need the phone and the PC to be on a different VLAN using the same switch port Fa0/1. Is it possible? Is there a sub-interface on switches?
My old setup was that all ODD ports where on VLAN 10 for DATA and EVEN ports on VLAN 150 for VOICE.
What is your current setup?
Please feel free to toss in some recommendation. Thanks in advance.
John Blakley
Generally, you'd configure your switchport like:
int fa0/1
switchport mode access
switchport access vlan 10
switchport voice vlan 150
Some implementations, like mine for instance, use trunk ports because I don't have Cisco switches everywhere:
int fa0/1
switchport mode trunk
switchpor trunk native vlan 10
switchport trunk allowed vlan 10,150
Then your phone would be responsible for tagging the 150 vlan. The most preferred is the first one.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
int fa0/1
int fa0/1
HTH,
John
Ganesh Hariharan
Hello ,
As stated in above post you can try the below configuration template
config t
interface FastEthernet 2/3
switchport access vlan 15
switchport voice vlan 16
OR
config t
switchport access vlan 16
switchport voice vlan dot1p
Hope to Help !!
Ganesh
