how to apply policymap to vlan interface not n router interface
Dr.X
Level 2
Level 2
hi ,
i have a router that IS A GATEWAY for internet ,  and another router which is Bras which is used to connect to Dslam
my request is , i want to gurantee didicted cir for specific vlan which is vlan 10
im using subinterface connect to router gateway which is the gateway of my vlan 10.
the problem is , i cant use policymap on subinterface !!!!!!!! it is not allowed to use it, im using router ios 7206 .
so i began to think in another solution which is applying the polivy map on the interface Gi0/1 as u see from my gigure below ,
but the problem is , the cpu  takse high and rech up to 90 % , it consume 15 % after adding the polivy map >
i want a solution ,
could i use policy on the swithch ??? and consume the cpu on the other routers ???
is there any other optinal soultion to use QOS ?????
                                                            Bras router
                    switch vlan 10  ===========routerGi0/1=============>internet
regards
Ganesh Hariharan
Ahmed M Alzaeem wrote:
hi ,
i want a solution ,
                                                            Bras router
regards
Hello ,
Check out the below link for policy map configuration
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/administration/guide/mapolcy.pdf
Hope to Help !!
Ganesh
