switch QoS configuration
pfrancis3
Hello, I notice on a switch that the following commands are present. My question is are these commands auto generated by the auto QoS command or have they been manually selected and entered by a previous operator ?
mls qos map policed-dscp 0 24 26 46 to 8
mls qos map cos-dscp 0 8 16 24 40 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 25 32 34 36
mls qos srr-queue output dscp-map queue 2 threshold 1 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 3 10 12 14
mls qos queue-set output 1 threshold 2 70 80 100 100
mls qos queue-set output 1 threshold 4 40 100 100 100
mls qos
Mark Malone
they are auto generated when mls is enabled but can be tweaked if required , each platform based on there hardware ability would have different queue sets and thresholds
from a 3560
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
That might not always be the case.
I just configured mls qos on a 3750, booted without a startup config, running 12.2(55)SE7, and no other commands were added to the running config beyond the mls qos command.
However, if I use an auto QoS command on an interface, then I get these QoS related commands:
!Contextual Config Diffs:
+mls qos map policed-dscp  0 10 18 24 46 to 8
+mls qos map cos-dscp 0 8 16 24 32 46 48 56
+mls qos srr-queue input bandwidth 70 30
+mls qos srr-queue input threshold 1 80 90
+mls qos srr-queue input priority-queue 2 bandwidth 30
+mls qos srr-queue input cos-map queue 1 threshold 2 3
+mls qos srr-queue input cos-map queue 1 threshold 3 6 7
+mls qos srr-queue input cos-map queue 2 threshold 1 4
+mls qos srr-queue input dscp-map queue 1 threshold 2 24
+mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
+mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
+mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
+mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
+mls qos srr-queue output cos-map queue 1 threshold 3 4 5
+mls qos srr-queue output cos-map queue 2 threshold 1 2
+mls qos srr-queue output cos-map queue 2 threshold 2 3
+mls qos srr-queue output cos-map queue 2 threshold 3 6 7
+mls qos srr-queue output cos-map queue 3 threshold 3 0
+mls qos srr-queue output cos-map queue 4 threshold 3 1
+mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
+mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
+mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
+mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
+mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
+mls qos srr-queue output dscp-map queue 2 threshold 2 24
+mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
+mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
+mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
+mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
+mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
+mls qos queue-set output 1 threshold 1 100 100 50 200
+mls qos queue-set output 1 threshold 2 125 125 100 400
+mls qos queue-set output 1 threshold 3 100 100 100 400
+mls qos queue-set output 1 threshold 4 60 150 50 200
+mls qos queue-set output 1 buffers 15 25 40 20
+mls qos
+auto qos srnd4
+class-map match-all AUTOQOS_VOIP_DATA_CLASS
 +match ip dscp ef
+class-map match-all AUTOQOS_DEFAULT_CLASS
 +match access-group name AUTOQOS-ACL-DEFAULT
+class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
 +match ip dscp cs3
+policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
 +class AUTOQOS_VOIP_DATA_CLASS
  +set dscp ef
  +police 128000 8000 exceed-action policed-dscp-transmit
 +class AUTOQOS_VOIP_SIGNAL_CLASS
  +set dscp cs3
  +police 32000 8000 exceed-action policed-dscp-transmit
 +class AUTOQOS_DEFAULT_CLASS
  +set dscp default
  +police 10000000 8000 exceed-action policed-dscp-transmit
interface GigabitEthernet1/0/1
 +srr-queue bandwidth share 1 30 35 5
 +priority-queue out
 +mls qos trust device cisco-phone
 +mls qos trust cos
 +auto qos voip cisco-phone
 +service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
+ip access-list extended AUTOQOS-ACL-DEFAULT
 +permit ip any any
