ACL help
kartik.shah1
Level 3
Level 3
I have two Cisco 3750 catalyst switches running in stack. Here i have vlan 15 for management, vlan 16 for server. I have user vlans - 201,202, 203 & 205. Inter vlan routing is enable on cisco switch. Now all users can access my servers and other management devices as intervlan routing is enable. Can any one guide me how i can add access control list to deny the access of vlan 15 & 16.
Regards,,
Mark Malone
Hi This is just an example you can block the subnets on the vlan interfaces from speaking to each other
block each subnet in and out but allow everything else , add it to each vlan you require
Interface vlan 201
ip access-group VLANACL in
ip access-group VLANACL out
Interface vlan 202
ip access-list extend VLANACL
10 deny ip 192.168.100.0 0.0.0.255 192.168.10.0 0.0.0.255 --vlan 201 not speak to 202
20 deny ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255--vlan 202 not speak to 203
30 permit ip any any
Hi Mark Malone,
Thank you for Support !
i have not configured interface vlan for vlan 201,202 & 203. Thing is that Users in vlan 201,202 & 203 should not get access of vlan 15 & vlan 16.
regards,
so where do the vlans break out of no SVI ? is it through sub-ints on the router side ?
if your going to stop vlans speaking to each other by ip it needs to be done at the SVI Vlan interface/sub-interface as its ip based interface , if you don't have vlan interfaces and your trying to block at layer 2 you would need to block by macs with mac acl or vlan acl if supported
Or use private vlans to stop them speaking to each other is another option
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_50_se/configuration/guide/scg/swpvlan.pdf
vacl if your device supports it may work for you but not all platforms support it
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/4_1/nx-os/security/configuration/guide/sec_nx-os-cfg/sec_vlanacls.pdf
Hi Mark Malone,
Scenario is on vlan 201,202,203 are individually connected to PPPOE server.
Users are getting PPPOE IP from this. So is there any other way we can use access list?
Regards,,
