Switch QoS show policy-map interface question
osw200051
Hi all,
Could anyone can tell me why the output showed "0" packets but the "bytes output" is increasing?
Is that the queuing value so it shows "0" ?
Class-map: voice-traffic (match-any)
0 packets
Match: cos 6
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
(total drops) 0
(bytes output) 74000
bandwidth 1% (100000 kbps)
queue-buffers ratio 1
Class-map: class-default (match-any)
0 packets
Match: any
Queueing
(total drops) 0
(bytes output) 5093009215
bandwidth 80% (8000000 kbps)
queue-buffers ratio 70
Thank you,
Giuseppe Larosa
Hello @osw200051 ,
this can be a platform limitation or a software bug
what is the switch model ?
Can you post
show version
Hope to help
Giuseppe
HI,
Thanks for the reply.
The model and version is below :-)
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PD 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
2 52 WS-C3650-48PD 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
3 52 WS-C3650-48PD 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
4 52 WS-C3650-48PD 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
5 52 WS-C3650-48PD 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
