Switch question
adhityakarthik
Level 3
Level 3
Dear all
i have to check and prepare a list with all the ports that have not been used for more than 10 weeks on cisco switch 3548
Can some one tell me how to get the data using ciscoworks or manually
Thanking in anticipation
Karthik
regd
Karthik
dave.keith
Level 5
Level 5
I use a small SNMP utility called getif for this purpose. Here is the method :
- get sysuptime
- get ifoperstatus , note those that are down
- get iflastchange , which is the sysuptime when the interface went into the state it is in
- compare iflastchange on ports that are down with sysuptime , a difference of 70 days or more based on your criteria
- note that if the lastchange time is very close to 0, the the port has been in that state since the switch poweron
Dave
Dear Dave,
Thanks very much for the update,
Could you please should i run these commands on switch or is there any other method
thanks
Karthik
GetIF is a goooooood freeware to do your job.
If you want to do CLI on the 3548XL, try this:
sh controllers ethernet-controller
This will show you send and receive statistics including the errors. If you want to clear it, it's "clear controllers ethernet-controller ".
Is this what you are looking for?
