Switch replacement or clone.
f-akyol66
Community Member
Hi my network guys,
Im a junior networkemployee and i must replace a broken swtich for a company for the 1st time.
The situation is: Meraki Switch sat-mill-01 is broken.
A new same model switch witch MAC ac:XX:XX:XX:4e:54
So the new switch ac:XX:XX:XX:4e:54 is connected to a other switch SAT-WERP-01 on port 2.
What must I do now? The customer wants to replace de broken switch, what must I do remotly how to clone the broken old switch to the new switch?
Could you tell me step-by-step.
I work Remotly.
aleabrahao
Meraki Community All-Star
Switch cloning after the RMA
Once you have received a replacement MS switch, you can clone your configuration from your old standalone switch to your new switch by following the instructions in this document 'Switch Cloning'.
If the switch to be replaced is a stack member, however, consult the instructions in our switch stacking documentation, under the section Replacing and Cloning Stack Members.
Full doc: https://documentation.meraki.com/MS/Other_Topics/Troubleshooting_and_Replacing_a_Faulty_MS_Switch
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
