Switch - Revision number
webstd.design
How switches assigns Revision number and what is it? How can I change this number? Also interested , where can I read about this number
7 Replies 7
Jon Marshall
Do you mean the VTP revision number ?
Jon
yes
Okay, it used by VTP to keep track of the vlan database. So you have one of your switches as a VTP server and the rest are VTP clients. Assuming the VTP revision number is 0.
You add a new vlan on the VTP server switch and save the config. When you do this the VTP revision number is then incremented by 1 on the VTP server switch.
This VTP server switch then sends out a VTP update message to the other switches and these switches then check their revision number against the one in the VTP update message. The revision number in the update is 1 and the clients VTP revision number is 0 so they know they have received a message with a more up to date vlan database. So they update their own vlan database info based on the VTP message.
Each time a vlan is created/deleted/modfied on the VTP server the revision number is incremented on the VTP server.
Jon
And how I can be sure, that VTP client willn't become VTP server?
What useful commands can I use?
It won't become the VTP server unless you make it the VTP server ie. you would need to make the change yourself
switch(config)# vtp mode server
"sh vtp status" will show you the status of the switch.
One other thing. When adding a new switch to your network always make sure the revision number is 0 and that you have set the switch to be a VTP client (or transparent).
To ensure the revision number is 0 on the switch change the vtp mode to transparent and then back to client mode.
Jon
As I understood, I cann't see revision number by
default with some command?
You can see the configuration revision number with the following commands -
IOS based switch = "sh vtp status"
CatOS based switch = "sh vtp domain"
Jon
